I don't know much about acsenders but I assume the croll is the smaller ropegrab that attaches to your chest?
I've heard someone use a short(ish) webbing strop looped diagonally across the chest one way then the other (so it goes over each shoulder once and then under each arm once) With the croll attached where the strap crosses over the chest (and of course, to the harness)
The webbing strop also had an adjustable buckle, so on second thought, it was probably purpose built for the croll.
I use a Petzl Torse.
Not much additional outlay.
How are you attaching the Croll to the butterfly?
I'm using a carabiner onto a ring on the bridge, there is my bomb proof attachment. i have no means of attaching a standard chest harness.
Maybe i'll just go back to my innertube
Bungee cord loop.. two small tool crabs. Clip one to the top of the croll. one half of the loop either side of your neck and clip the other crab to a loop on the back of your harness??
Works for me.place around with the length of the loop so its still fairly tight when you sit and not too tight on the stand part of the movement. hope this helps..
