Hi Mathew, if you add yourself to the tip sites (linked here or above) you might get some luck there.
Noting that most tree surgeons and so on working regularly in your area will be sorted where to get rid of their waste, you are more likely to get occasional loads from people working outside their area and not wanting to return to their usual places (time driving 'home' costs). It helps if you can be accessible as you can - a drive to tip onto helps, no locked gates, able to take any waste on offer and so on.
Second thing is to take a walk around, listen out for chainsaws working (they arn't hard to find), weird as it may be but not every tree surgeon is a member here, won't see the tip sites. You might get lucky, a face to face conversation can get results - though again be prepared to leave a number and post code (goes into the pile of phone numbers in the van) - if you are closer or more convenient than a usual tip that can help.
In the tip sites add in that you are willing to give a consideration for time and petrol.
Last one, local knowledge, there was a fella with a yard - forget where - think advertising on Gum Tree advertising uncut logs delivered - might have been Rutherglen way
