Range Rover/Discovery/Evoque help needed?
Anyone got an Evoque or other Land-rover product that has suspension position sensors? The missus' Evoque had a new wishbone fitted and the drop link to the sensor was bust. I got a new sensor but the drop link seems to be in need of adjustment (cheap kin imported shite) but the fixing the the wishbone is lost! Does it just press fit over a stud or is there a bush or just a bolt? What size thread in to the wishbone? M5, M6, M8?
Just to tie this off, the spigot for the drop link was in the old wishbone but sheared off when trying to remove it. That and a drop link was £120 from Land-rover so, I drilled and tapped the spigot to M5, cut the head off a bolt and screwed that in lovely! The drop link was slotted back together and had a tie wrap secure the two halves! Decentish bodge job but it works!
