Sachss Dolmar 111 - looking for a rim sprocket
Got a hold of a dolmar 111 in pretty neat condition. I want a rim sprocket on it, does anyone know what the part number would be or who makes one that fits?
The original part number for the spur sprocket is #020 223 101
Edited by Milkgod
I assume you have the early type steel oil pump drive scroll, if you do you need item 21 plus associated spacers etc on parts diagram below, if you can't find one let me know. Probably L&S Engineering can supply the later part but not item 21 as I think NLA now. The later set up as per parts diagram are much better as the oil pump drive only when the chain is running, but you would have to change the oil pump and pump drive and washers etc, or get yourself a 520 parts saw as they come quite cheap and plentiful.
Makita DCS 430 520 parts manual.pdfMakita DCS 430 520 parts manual.pdf
