Just use the one for example from 6000/6800i, you can use this later coil as a replacement for even early points saws 112 etc. You can find s/h or new ones or use AM ones. I have used both and to be honest I have had 100% success rate ( probably 20 odd) from the AM ones I used. You just have to fit a spade connector on the wire and shave a little off the post to allow the coil to fit flush, it is obvious when you come to fit one. Unscrew and cut HT lead to length. They are about £16 each. Of course fitting AM can be a crap shoot but it's your choice. Just make sure to use NGK BPMR7A spark plugs
