I work for a company of architects and am struck by how inconsistent advice from tree officers at local authorities can be. We appoint a number of tree consultants to work on our behalf and value their advice, however it often falls on deaf ears.
My current bugbear is how inconsistent officers can be over works outside an RPA. Yes I said "outside" an RPA!
As I understand it BS5837 has prescriptive advice in relation to work inside of an RPA but does not need to provide advice for ground works outside of an RPA because, I presume, it can be considered that the protection of the tree has been suitably considered against the advice BS5837. Am I right?
What do I do about this?
Does anyone work with Tree Officers that seem to create arbitray rules surrouding RPAs?
To answer your questions.
Yes.
Tell them to f*&% off as nicely as possible.
Yes, but it's progressively rrare on accont of the 2nd answer.
Slight amendment to what I said.
The RPA is quite arbitrary and there is no evidence that it is correct, and plenty of evidence that it isn't. But isn't a development context it is unfortunately considered industry best practice.
What it isn't is the extent of rooting. The full extent is probably abot 4 times as large. So if the TO is making a fuss abut a TPO application and proposals to work close to tree but outside RPA, there may be legitimate grounds to make a fuss. Also if it's an ancieint or veteran tree.
Edited by daltontrees
