Well it is the season and the blowers are in good use now.
Ive seen plenty of fairly new hand helds with holes in the pump diaphragm, its the thin plastic thing in the carb that looks like this4149-121-4801.jpg.c676a099af422b26aa830abe0280f624.jpg
If your machine is pouring fuel into the engine or the primer pump isnt drawing fuel through then it may have a hole in it.
Here's an decent example, 2020 bg56 in today. Poor starting and running, dying on tick over. It ran ok ish on full throttle.
You cant really tell just by looking at the gasket...
You need to hold it up to a light
