Hi!
I bought a used cs100 a couple of weeks ago, advertised as needing a new battery so I tested it with the pull cord and got it working.
Since I've installed a new battery and it started fine but seemed to surge witch it didn't do before battery was fitted.
3 jobs into it's service it has started to die during jobs and it won't turn over with the key, we checked for debris in the feed and shoot - all good, removed the drum, all good, checked the belts, all good - then my groundie wired it up to his truck, I started the pull cord and we got it working again??
After a while we removed the jump cables and the key started the engine again?
Any advice would be greatly appreciated.
Cheers
  • 6 months later...
