If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
E Milner
Hi - I have problem with one of 3 silver birches planted 4 years ago.
bark has holes in side, small dots and also larger holes that go through to inside of tree and look like they’ve been pecked with woodpecker ??
leaves are smaller than the other 2 trees and yellowing with brown dots
Any ideas of what’s causing and any remedies ??
1 answer to this question
Register a new accountSign in
