As above, a flails needs a large hydraulic pump and pressure.  Think of the large tractors you see flail hedges crawling along at high revs. You need to match the spec (generally two numbers as a range of l/min) of your digger to the same for the flail.  Best to have a range that is a close match rather than push it.
