I'm going to buy a wee chipper is there much difference between the jo beau 300 and 400?
I would read another thread on here called Shreks wee chippers.
I have a L300 no complaints in 2 years.
i hired a m300 before buying the m400 yeh there is alot off difference between them. go for the m400 if i was you but im not shore where u will get one from as i dont think they are being imported at the moment best way to find out would be to ring fletcher stewart.
if not look at steves wee greenmech 18hp thats a good bit off kit, that 18hp greenmech is as good as a m400
The 300 has a 300mm wide drum opening with 80mm capacity running a 13hp Honda engine. The 400 has 400mm wide drum opening with 100mm capacity running a 20hp Honda engine. All Jo-Beau products are now available through Prochip. More details will follow.
