Hi
I've read a bit about beech bark disease. Do you think this is it ? The white material was mostly under ivy and the red patches are small but spread more widely.
Cheers
Andy
Unfortunately that’s impossible to answer without seeing the tree and carrying out a thorough inspection.  However, that said, BBD isn’t usually a problem until it’s in an advanced stage, where it has ‘killed’ large amounts of bark, but by which time secondary pathogens may well be an issue in your declining tree.
If in any doubt about your trees health / stability, it’s best to commission an independent inspection and report to establish the situation.
In the meantime you could scrub the scale insect off with a stiff brush and mild detergent - I’ve also heard that it can be pressure washed off, but never done it myself.
