On 02/09/2022 at 13:11, Derekl said:
Hi, just used the machine for 30min, worked perfectly, stopped to remove some trapped debris and the engine was fine but the blades would not move, they were free but there did not seem to be enough power to drive the blade! The base of the gearbox was very hot so I am wondering if there is an expansion issue of the clutch when it gets hot?
Two questions:
- when it's hot and you have the problem of the blades not moving, does engine rev up ?
- if not, is engine trying to increase speed, ie making more noise but not reving (so like a chainsaw with the chain brake on) ?
