On 29/08/2022 at 18:37, naturarbo said:
Yes.
I presume the standard way is sling in the groove and rig line through the ring, is that correct?
Yes that it.
What material slings and size do you use for your rings when setting them up with the rigging line going around the outside of the ring?
mostly tRex 19.1mm...I spliced 1 dead eye, 1 ultrasling and 1 whoopie??? wich turns onto a retrivable rigging anchor with 2 rings when needed, tree will always define the tools used, of course
