I have a tip site listed on this site, but I wanted to update some of the info on there. Maybe I am being a bit dense but I can not find a way to edit the info?
I am just a domestic site looking for any sort of wood that I can process for personal fire wood, but I am also now after clean wood chips for creating pathways around our land. I also wanted to edit the info on where wood/chippings could be left but have failed to find a way to achieve this.
Thanks
5 hours ago, Steve Bullman said:
At the bottom of your listing look for where it says profile actions
Thank you was clearly just not looking hard enough.
Can I ask with woodchips what does the "with limitations' mean?
If you need to restrict certain types of wood chips, for example if using for livestock you would not want Yew and some other poisonous species. If you want it for composting or putting down on paths for example then that won’t apply to you.
