Help please...
I replaced carburetor, fuel line, and fuel filter. When I started it, it started wonderfully. Then after it warm up or so, it starts idling high AND low.
After turning it off, I start it and either idles low or high.
8 hours ago, ChrisNewport said:
did you inspect the rubber hose part number
530 05 34 35
Hose
 they split and cause problems
Nope. Will look into it next.
Do I have to get that part or just get the part from a 141 parts diagram?
  • 2 months later...
3 minutes ago, ChrisNewport said:
Youve had an air leak then, i would take the exhaust off and have a look at the condition of the piston through the exhaust port.
Okay, thanks @ChrisNewport.
Anything I should be looking out for when I examine the piston?
Just now, ChrisNewport said:
should be nice and smooth, and not have what looks like rough melted vertical lines in it
Got it, will look into it once more if I ever have the time again.
Will update again. Thanks.
