Its not really that amazing, ice has a very low friction coefficient like steel wheel on steel rails and ~5 tonnes of horses with studded shoes and a high ground pressure on ice would have more grip to pull than on almost any other surface, so 6 big horses would be able to get over 100 tonnes moving on rails or ice. ;)
Be it animal or mechanical HP it takes very little power to move massive weights at low speed, its more about having enough weigh & traction for the power you do have.
Look at it another way I weight just under 100kg and I can just about push my Unimog that weighs 6.1 tonnes on flat ground a cupple of meters, that just over 61 times my weight, or look at it another way a land rover road railer will move 300 tonnes and a Unimog road railer will move over 1000 tonnes both at over 15mph
I was thinking more of the effort required to cut the timber and load up the sledge.
