Start with both units off .
Press and hold the flat button on the left for approx 8 secs on each unit until they flash blue and red .
Once they find each other they will flash just blue and will have beeped . When this happens press the same flat l/h button once....wait a few seconds and they’ll make a rising succession of beeps and you’re in .
If you lose contact after that ie go out of range then they usually will find each other, although you can press the flat l/h button twice followed by the chunky round volume button once and they should again connect .
