Spare part for rubber hitch between motor and drive belt double pump
Hi,
not sure if this is a problem of my previous attempts to replace the V-belt of the belt drive pump (have worked >50h since then). But today the rubber coupling part virtually exploded into pieces. The metal shaft is still looking perfect, but the two rubber parts flew into pieces. For security I added a screenshot from the spare parts binder with one half of the hitch colored red.
I tried to look the two parts up in the spar parts binder but had no luck, not labeled. Jase or other, can you provide me with the respective numbers so I can order at my local dealer?
Thanks in advance,
Soeren
Edited by Soeren
Thanks Jase,
one rubber part is labeled something like "Centaflex, Mikipulley, Size 2". In theory one can find them on the internet, but there are different types available. Also many have three bolts, but the Arbtrak has only 2 bolts + 2 screws on the motor side plus 2+2 screws on the pump side.
Best,
Soeren
Edited by Soeren
Read more
