You could always check flea bay from time to time.  As it seems that part fits a few models [emoji6]
Yeah, 051,075 and 076 are all basically the same saw.
[emoji106]
I’m after a clutch and clutch nut for a 076av ,if anyone knows of where I could get these parts, came loose while milling and the nut is long lost in a pile of shavings.
Really good saw , with a big bar on kickback is a very rare thing, but obviously a chain break is built in safety .
Nip every nut and bolt up regularly as said above they do loosen, I’ve used mine for many years and milled massive sections with zero issues other than the clutch .
How did you do your clutch up?
