  • 0
Straighten fruit tree
Garry Edwards
Question
1 answer to this question
  • 1
Yes, no problem. If it is still relatively loose in the ground and will straighten without digging, then just put a couple of sturdy stakes with a cross member and affix the tree with a rubber tie and buffer.  If the roots have become so well established that it won't budge then you will need to excavate around the tree to loosen its grip before straightening and supporting it again.  It is likely that some root severance may occur, so this is best done in the dormant season.  Just remember to keep it well watered in the next growing season.
