Mastersplit wp36
Dan J
How's the oil temp?
Saw going slow is normally a sign that the splitting ram is not triggering the valve to stop flow going to it.  sign of this is that you'll  be able to hear the pump labouring a little when the ram returns and before you pull the lever to saw. Oil temp will rise quickly and there's a good chance it will go black if you use it like this for too long.
There's two trigger blocks under the infeed, the one closest to the saw end could need a touch of adjustment. No 13 in the diagram   BTW it's a pig to adjust
Read more
