Used in good condition
Log conveyor Jansen FB-500
The 5 metre long conveyor belt is ideally suited for the transportation of split wood, but can also be used universally. Due to the simple but well thought out construction, assembly and disassembly time is incredibly short.
The carriers, made of 3mm thick folded sheet metal, guarantee the corresponding feed rate. The transport belt runs at a speed of 0.8 m/s. The maximum ejection height is just under 2 metres.
The device is delivered well packed in a wooden crate. You should allow approx. 30 minutes for initial assembly.
Compare our machines with competing products! You won’t find anything better. We didn’t only develop these devices ourselves, but also offer excellent service (master technicians workshop) and spare parts. We have almost every part in stock. In the event of questions or problems we are only a phone call away. With us you speak with knowledgeable staff and not with “call-centre agents”!
We have all of our products assembled and ready for operation in our exhibition halls. We would love for you to come by to test them!
Technical specifications:
  • Engine: 230V
  • Power: 370 Watt
  • Length: 5 m
  • Ejection height: max. 1.95 m
  • Belt speed: 0.8 m/s
  • Belt width: 100 mm
  • Belt channel width: 400 mm
  • Carrier height: 27 mm
  • Distance between carriers: 980 mm
  • Diameter pulley: 120mm
  • Diameter wheels: 240 mm
  • Dimensions max.: 5000x1300x1950 mm (LxWxH)
  • Measurements of packaging: 2150x800x550 mm (LxWxH)
  • Weight: approx. 130 kg
  • Weight including packing: 155 kG
£450.00
collection
  • 2 months later...
Ă—
Ă—
