make a small steel box that then engine will fit in, put a hinged side that can be padlocked, then cut a hole in the opposite side big enough to get the sawhead and shaft through. now get a piece of steel tube slightly bigger than the whole you cut and weld it to the box you have made.
totally secure site box that will fit a pole saw, keep it out of sight and cheap to make
