Lack of oil
waterworks
I have a Jonsered 2065 and the chain oil is coming through from the pump but even though all the oil channels are clear in the bar I'm not getting any visible oil on the chain, my normal setting is maximum and I have always started every sawing session with an oil test to check its spraying off the bar tip, I'm not getting anything now and its the same bar.
Any ideas whats gone wrong ?
So to clarify, when run without the bar, you are getting oil coming out of the channel the saw uses to oil the bar and in good amounts?
If this is so, and the oil hole is clear in the bar, it should oil. If it doesn't, check the bar oil hole lines up with the channel - sometimes it doesn't if the bar is the wrong one or the bar is at full extension due to a slack and worn chain.
Other than that, the oil pump isn't producing enough pressure to push the oil through.
