Calculating the Age Of Trees
Here is John White's method for estimating the age of veteran and ancient trees. I have used it to calculate the age of just mature trees too.
http://www.ancienttreeforum.co.uk/wp-content/uploads/2015/03/John-White-estimating-file-pdf.pdf
Alternatively you could use a resistance drill eg Resistograph or PD to measure the thickness of the annual rings, then calculate it from that.
