Hi I would like to find out a woodland
is covered by a tpo what can be down to manage it or remove these larch trees 30% mainly all leaning and falling over all over the place the soil/organic matter  level has raised so much that  trees have fallen over around 2ft  diameter and the the ground level has raised so much over the yrs that you can’t see a fallen trees completely covered it’s not been managed for over 50 yrs tpo was put on in 1988
being the tree tree roots are so low in the ground would the tree root protection still count ? As I would like to get a avant in there and start clearing the bramble etc and remove fallen trees ?
what grounds could I tell the la the trees  need to be removed as they are really crappy larch  and small spindley birch Further down the hill is chestnut and beech that do look ok
any help or plans to manage the woods etc Why do the larch keep falling is it because the soil/ organic matter level is so high is so soft that you can dig a 2ft hole with a set of fencing spoons in three scoops  ??
