I think I need to source a replacement green button for my entec, I believe is is 'sticking'.
The machine sometimes sticks in forward feeding mode, pressing the reverse button does nothing. If I repeatedly press the green button it resets/unsticks and I can reverse the rollers as normal. The stop bar operation is never affected. If after stopping I press the reverse button it does as it should, releasing the blue button makes the rollers run forwards without the need to press green.
I believe the green button is knackered and I am trying to source one as a replacement. Is it possible to buy the single buttons or does someone know the generic part number so i can order one from somewhere like RS components. I do not really want to spend £xhundred pounds for a full replacement control box when it is only a button costing a few pounds that needs replacing.
Thanks
Kev
Hi
You are correct that we recommend that the best thing to do is to replace the control box complete as the fwd button and contacts are not available anymore, however I have checked our stock and to my great surprise have found a button and contact.
Our part numbers are as follows
Green Fwd Button part no. 1260
Norm Open contacts part no. 2648
After these there are no more available, honest guys these are the last ones.
If you want them either contact your local dealer or if you have an account contact our spares dept.
regards
Timberwolf Technical Support.
Thanks for the reply.
After dismantling the switch box I have got the manufacturers part number. These switches are available from RS components for £9.58 each, I have ordered one and hopefully this sorts the problem.
Kevin
