hi all
problem with greenmech 15/23 eco arborist 2004 engine control box.when the chipper starts the revs only show between 1050 and 1125 when flat out ,So the no stress control dont work is there any way to set the box?
Probably the speed sensor not the box. Clean it and make sure it has not moved. Always check the simple things first.
hi mike
its the first thing i look at, cleaned it but no joy.
Hmm, odd one that. I presume that it is a proximity switch measuring the speed from up by the top pulley. Mike's suggestion to look at that was right in that you check the simply things (cheap) things first. Contact Greenmech on 01789 400044 asking for service or PM me or call me on 07774 282481 and we'll have a chat.
  • 1 month later...
