Husqvarna 455 Rancher
TommyT315
I set it with a business card like I usually do.
Got a reply from Husqvarna and they think it is more likely to be a bad new tank vent.
So I will tomorrow remove the vent all together and see how the saw works. Hopefully that will be the problem and get a replacement from the dealer. Here’s hoping ?
Yes, spot on, you are basically sucking air out replicating fuel leaving the tank and you would expect air to enter via the vent returning the tank to atmospheric pressure (no pressure or vacuum -Zero) in under a second with no build up of vacuum in the tank that remains present for a couple of seconds or more.
You may have sealed the new vent in with some compound that may have sealed the vent?
