Hi guys I was wondering what would be the set up for hexagonal wheel/ 6 point multi tip cutting wheel using rhino teeth...
I came across one thread where it is recommended to use two multi-tips together with rhino teeth... ''We found the debris was cleared better by keeping a pair of old multi-tips in the two inner-most positions and running Rhinos in the other four''
My question is what rhino teeth to use in outer-most position and middle position...? There are two types... Standard and XL...
2 Standard teeth for outer-most position and 2 XL for middle position? or the other way round?
Thanks a lot
L
Edited by Drikonus
