I’m not sure about a split line, I have run my fingers along them all and not found anything, looking at the lines I’d say they have grease all the way through but it’s hard to tell as it not opaque. So it’s just a light brown colour. Hoping its not just grease on the line and it is actually running all the way through. As I said I’m going to give it a good look through tomorrow evening and try and solve the issue.
How’s your ST6 running now? Would you like someone here from Forst to give you a ring tomorrow?
Thank you but I’m not really going to get a chance to speak tomorrow day as Work is going to be a little hectic. However if I can’t diagnose the issue I may call you guys up on Thursday to see if I can get to the bottom of it.
Cheers :-)
Update on the situation. I cleared out the drop plate under the bottom roller and the squeak has not been back. There were a couple of bits of chip wedged along the side of the rollers also so that may have been the issue. Thanks Mick for the tip.
Need to set aside more time to clean the equipment out I think.
