1 minute ago, spudulike said:
That stalling is probably the L screw being a bit lean, the H screw too rich making the saw load up under load or a bit of an air leak.
Have tried various positions on the L and idle screws but it hasn’t helped (plus it’s hard to adjust properly when the saw won’t idle normally...) hadn’t really thought of adjusting the H screw tbh, will try leaning that up a bit tomorrow and see if it helps. If tha doesn’t help I guess I’ll have to look for an air leak. There does seem to be quite a lot of buildup in the muffler (from what I can see through the exhaust port), do you think there’s any chance that could be causing it?
Thanks, James
