Do you mean the main flywheel itself? What is actually wrong with it? The nose shaft is replaceable if the bearings have worn the shaft and the alloy fins (if later flywheel) are replaceable. Machine shops will be able to rectify any damage and balance it for you.
Should be "serviceable" in one form or another...
