Hi there men i am going to change my main flywheel bearings on my chipper on Monday any hints/tips??
Also i understand that the front bearing(engine side looking from the side down on the the chipper) is a standard bearing but the back one is a hardened/different one ?? it looks slightly smaller and wider but only when you look close.
Will i get the bearings from a standard bearing supplier using the numbers ??
Any help would be welcome??
Cheers !!
Regards Dan
