Hi all,
Some basic dumbarse questions I hope you can help me with:
Am I right in believing that the only recourse a LA can have to stop treework being carried in a Conservation Area is to put on a TPO before the end of 6 weeks after receiving a notice of intent describing the work?
Or do they have other powers to stop work?
Also, if a LA requests clarification or further info, does the 6 weeks period start again?
Yes, no, probably I would say.
However, if they can get you to formally withdraw your Sect. 211 notice and reissue with more acceptable proposals that can sometimes / occasionally be an option.
No 'other powers' under Planning legislation unless perhaps a condition prevails...unlikely generally.
If they, then LPA, consider your Sect. 211 notice to be vague / ambiguous they shouldn't register it in the first instance so the 6 weeks time period doesn't start running.
I'm sure other will clarify further...hopefully not disagree tho unless a dumbarse reply  :/ :D
Cheers.
Paul
Edited by AA Teccie (Paul)
