I recently brought a year 2000 timberwolf 18/100
Few questions
Is there anywhere to get a manual for machine and 18hp kohler
what battery should be fitted?
the flyweel seems to require a fair bit of force to turn by hand - normal or sign of worn bearing? How much are bearings if they do go? ( directly connected to engine)
material seems to get drawn in to the bottom right hand corner of feed (doesnt like to chip on the left of infeed if that makes sense) is this normal?
cheers
Manual can be got from timberwolf site.
Yes the flywheel will be hard to turn as it's attached to the stationary engine via the belts.
Yeah that sounds right on the infeed from memory but sold mine 2 years ago so could be wrong
