Ended up using my pulley save to make a retrievable top anchor. Dont think i have read about it any place but it did seem to work well and pulled out ok despite going through a couple of NC re-directs- the set up was the same as when i use a normal cambium saver in this set up - using a Alpine butterfly backed up with a krab - the only danger i really see is the pulley wheel busting - the load could be a bit oddly balanced on it - but figured the becket would stop any major accidents.
Anyone else used this method?
Also - the tail end that runs to the ground for retrieval - could this be used as an emergency access line?
