Jensen a530xl 2008
Petethegardener
not sure if your machine is the same but the work one was just a small square panel to remove then a large bolt to remove and an angled pressure bracket to remove then in the end of the anvil there is a small threaded hole, find a long bolt to fit then grip the bolt and slide the anvil out, it could be a bit stuborn, then you can reverse the anvil if the other edge is good. hope that makes sense and is the same for your machine.
carl
