  • 2 months later...
I had a 55 some years back & IIRC I found a bar from a Mac 1/10 fitted, from some notes I made at the time the bar mount was Carlton 41, Oregon D276, Windsor TMX, GB MA. the bolt slot was 8MM If you go to Chainsaw Collectors Corner & look up bar mount for a Mac 1/10 there is a silhouette drawing that should help to see if this mount will fit as to the availability if correct I'm afraid I cannot help Good Luck
