385 clutch cover casing ,
huskywilson
Hi Guys , recently got a 385 xp and have discovered the the clutch side cover is damaged , whoever had it previously repeatedly used excessive force to tighten the bar nuts or it got jammed in a big log or something which has cracked the casing and buckled it a bit which has over time worn the alloy away and the bar tensioner will only travel 2/3 of the way up due to the distortion , it still works ok but its irrititating me now , anyone have a decent casing they could sell me ? , its the same casing fitted to most of the bigger 3 series saws , 365/371/372/385 390 and the 570/575 , OEM part No is 537 00 40 with side adjuster
thanks for any input
Roy
The use of the word "casing" is a bit confusing here - but believe the question really is about the clutch cover?
If so, the same covers will fit all those models (and more), but the 371s and many 365s had a front chain adjuster (and no adjuster in the cover).
Different part numbers can be about color, minor changes in production, and of course standard vs. wide.
yeah sorry it is the clutch cover i meant , it has the side adjuster and its using my loaner just now from my 2013 372 xp , but i still havn't managed to track down a replacement , yet , do you have one ?
