Going rate for Spraying per M2
mattyb75
There are several factors that are personal to you and the job that would affect the price, including the height you hold the wand from the ground (the effects the swadth width), the speed you can walk across the ground, the rate of flow from your own equipment and not forgetting the chems you are using. All these and more affect the price of the job.
It is possible to calculate all this up with some accuracy, and almost pointless to give a bland '5p a spot' type answer.
Have you done the PA6? If so you should be able to work it out as it is all part of the course.
