Hi,
I recently bought a newly reconditioned CM220 MT55, which is an amazing machine, it has done only 15 hours work before taking a fortnight off over Christmas .. Upon going through the start-up procedure, the machine will start fairly easily.. run for approx 3-4 seconds and then stop..
all fluids are at the correct level. judging by how easily it starts (a few cranks, same as before Christmas) I imagine the battery is OK. I have re-read the start-up procedure section of the manual a few times.. I believe incorrect use of the 'low oil pressure override button' may cause similar symptoms.. and have ensured correct use.. apart from one occasion.. curiously, the machine will start and run for the same 3-4 seconds before stopping if the override button isn't pressed at all!?
is there anything else I could try, or have I found my problem? wiring/oil pump?
Any help will be greatly appreciated,
Kind Regards,
Greg Johnson
