Schliesing 200 mx roller problems
Hi all, i have a Schliesing 200mx.
When i feed the machine the no stress and rollers work fine and then without any reason the rollers will slow down as if there are not enough revs.
If i knock the throttle down and rev it up again it works again but will the rollers will intermittently slow down so i have to go through the throttle process again.
Can anybody shed any light on this please?
Could it be faulty wiring to the solenoid or possibly be the solenoid itself?
I have also taken the earth off the solenoid and the rollers pull through fine but the stress control doesn't work.
Thanks in advance.
