DMM Product Recall Notice 14th September 2015
This recall encompasses all of the products in the table below. All models, all colours and all gate types are potentially affected by the dysfunction:
With the following serial numbers (these run sequentially):
If your carabiners meet the above criteria please carry out the user inspection as detailed on the next page.
The serial number can be found on the spine of the carabiner.
2014 Production - 14138xxxxX to 14365xxxxX
2015 Production - 15001xxxxX to 15254xxxxX
DMM are issuing a product recall, subject to user inspection. This document details the products that are affected by the recall and contains instructions to identify whether or not an affected product should be returned to DMM.
DMM Wales - Climbing Equipment & Industrial Equipment
14TH SEPTEMBER 2015 - V2
A36# Aero HMS
A91# Captive Eye
C41# 10mm Steel
Offset D
A872 Belay Master
A84# Klettersteig
C81# 12mm Steel
Offset D
A89# Boa 25kN
A33# Ultra D
C84# 12mm Steel
Klettersteig
A90# Boa 30kN
A82# Zodiac
C85# 12mm Steel Boa
A98K# Sidewinder
C45# 10mm Steel Oval
C96# Steel Captive Eye
PAGE 1
In a small percentage of carabiners the interaction between the internal coil spring (which gives the gate its closing action) and the gate pusher (the component that holds the spring against the carabiner body) may cause the gate pusher to displace, potentially preventing the gate from closing or the mechanism from locking completel
