hi all i am wondering if anyone might be able to help?
1: i was wondering if there might me a vertical shear bar in the CM202 as when i look down the "side walls" of the infeed right at the very end/shear bar position, the right hand side as you look through the rollers is round not square and flat, and i was wondering if there might be a way of replacing that?
2: my feed rollers will feed in ok with smaller brash but when and good size pulp wood goes in the rollers simply freeze and won't pull it in?
any help would be great and i can supply pics if need be?
chris
