Front scoop to fit on the forks of forklift truck. Can drive into material to scoop what you want up. Lift up on mast and then manually tip using quick release handle on side of scoop. Works well on woodchip, sawdust, sand etc. Cheap method of material loading if you have a masted forklift but […]
Read full advert at Arbtrader...
