compression tester Schrader valve? snapon not selling.
I also bought some of these bicycle valves out of interest, they work well, somewhere between the two on spring rate between the low pressure one and a std cheapo Schrader. Gave the same psi in the same amount of pulls as the low pressure ones, slightly more infact as I don't think you get the bounce at the top psi where the spring is so soft it shuts slowly and some of the trapped pressure escapes (at 250psi). Cheap too.
WWW.EBAY.CO.UK
WELDTITE SCHRADER VALVE CORES. 4 x SCHRADER VALVE CORES.
