Hi all i have just bought a used avant 635 loader,i want to run a splitter on front, off hydraulics.Not sure if it will work,it seems as all the hydraulics work from the joystick ie flow,return ,third service which has to be operated from the the cab !!how can i use it from outside the cab .must be a way i think....any advice ??.
I've been wondering this on the tractor front loader? On the Quicke joystick there is a 'float' position that clicks in if you push the joystick fully forward. I'm not sure if that's just dropping the boom under no pressure, or whether there is flow that could be tapped off?
