They are a bit of a pain, remove oil and fuel caps, remove 4 screws and pull the brake lever off its mounting and wiggle the recoil cover to free it up. Its around the handle and oil tank area its tight to get off, you need to use a bit of force to pull the handle at the side downwards and lift and kind of twist the recoil cover off.
